Postium Korea OBM-N240G Overview
Monitor your studio or field production with the quality-control-grade OBM-N240G 24" Wide Gamut QC-Grade LCD Monitor from Postium Korea. Utilizing a wide-gamut DCI-P3-capable 24" LCD display with a native resolution of 1920 x 1200, the OBM-N240G is ideal for HDR monitoring. The full-featured HD/SD broadcast and motion picture production monitor accepts signals at up to 1080p60 and features two 3G/HD-SDI inputs and two 3G/HD-SDI outputs. There is also an HDMI 1.3a input and analog component and composite inputs. The monitor boasts a 178° angle of view, 400 cd/m² brightness, and a 1500:1 contrast ratio. A power cable is included with the unit.
DCI-P3 color space is supported with a gamut ratio of 113.02% and total gamut coverage 98.24% for color-critical and QC monitoring applications.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content with support for PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. The HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
Color Space Dynamic Range Comparison (side-by-side, wipe position) allows you to compare different color spaces, gammas, HDR/SDR, camera logs, and other color settings side by side simultaneously. The comparison area can be selected and moved with a vertical wipe pattern.
False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: zebra, variable, ARRI, and comparison.
Built-In Camera Log to Linear Conversion LUTs
The monitor has built-in Camera Log to Linear Conversion LUTs from various camera manufacturers, including Log-C, C-Log, S-Log2, S-Log3, J-Log1, and more. Plus, custom 3D LUTs can be imported for accurate and consistent color matching between different displays and for DIT previews of customized 'looks' that have been created by third party color-grading applications. The LUT-converted content can then be output to downstream devices/monitors via the SDI loop out.
Postium Korea OBM-N240G 24" Wide Gamut QC-Grade LCD Monitor
Power Cord
Limited 1-Year Manufacturer Warranty (LCD Panel)
Limited 2-Year Manufacturer Warranty (Main Board)
