Postium Korea OBM-N310-NB Overview
Monitor your field production from a mobile truck with the OBM-N310-NB 32" LCD Monitor with 3G-SDI & Narrow Bezelfrom Postium Korea. The OBM-N310-NB is designed with a narrow bezel, which makes it optimized for OB van configurations, and offers 1920 x 1080 display resolution and a 178° viewing angle, with a brightness of 500 cd/m² and a 3000:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs. An HDMI 1.3a input provides additional options for bringing in video with embedded audio, and a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. There are also component and composite inputs for analog video. The monitor comes with its own power cord.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content. The OBM-N310-NB supports PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. Postium's HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
Focus Assist controls the aperture level of a video signal and displays images on screen with sharpened edges to help camera focus operation.  False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: zebra, variable, ARRI, and comparison.
  • Postium Korea OBM-N310-NB 32" LCD Monitor with 3G-SDI & Narrow Bezel
  • Limited 2-Year Manufacturer Warranty
SKU: OBM-N310-NB
$5,561.25Price
