Postium Korea OBM-Q240 Overview
Monitor up to four 1080p60 signals simultaneously on the screen with the OBM-Q240 24" Quad 3G-SDI Input/Display Monitor from Postium Korea. The versatile 24" monitor offers a 1920 x 1200 native display with a 16:10 aspect ratio, a 178° viewing angle, and 300 cd/m² brightness with a 1000:1 contrast ratio. It has four 3G-SDI inputs and four 3G-SDI outputs, as well as an HDMI 2.0 input, a 3.5mm analog stereo line in, a 3.5mm headphone out, and RJ45 connectivity for Ethernet, remote, and RS-422 control. The monitor comes with its own power cable.
Key Display Functions at a Glance
High Dynamic Range (HDR) Emulation
This function allows you to apply a High Dynamic Range display gamma curve to HDR content with support for PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. This HDR function enables you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction.
SDR/HDR Waveform Monitor and Vectorscope Display
SDR/HDR Waveform Monitor and Vectorscope Display modes enable you to monitor sources using the internal waveform and vectorscope individually or simultaneously. The position of the waveform and vectorscope can be moved between top left, top right, bottom right, and bottom Left. When HDR mode is set on, the HDR waveform is displayed on screen.
Adjustable Gamma Control
This control allows for incremental compensation between gamma correction values of 1.0 and 3.0—thereby ensuring that the decoded image isn't too bright (no gamma correction) or too dark (overcorrection).
In-Monitor Display (IMD) Function
The IMD function allows image source names and tally information to be displayed on the screen with an external remote function via Ethernet. TSL system protocol is supported. The color of the source name and tally color is selectable among white, red, green, blue, yellow, cyan, and magenta.
  • Postium Korea OBM-Q240 24" Quad 3G-SDI Input/Display Monitor
  • Limited 1-Year Manufacturer Warranty (LCD Panel)
  • Limited 2-Year Manufacturer Warranty (Main Board)
SKU: OBM-Q240
$5,295.00Price
