Postium Korea OBM-R210Q Overview
Monitor your field production from a mobile truck with the OBM-R210Q 21.5" Quad-Split Rack Mountable 3G-SDI LCD Monitor from Postium Korea. The 7 RU rack-mountable monitor features a narrow bezel, making it ideal for OB van configurations, and it offers 1920 x 1080 display resolution with a 178° viewing angle, 1500 cd/m² brightness, and a 3000:1 contrast ratio. It features four 3G-SDI inputs and four 3G-SDI outputs. An HDMI 2.0 input provides an additional option for bringing in video with embedded audio, and a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. The monitor comes with its own power cord.
High Dynamic Range (HDR) applies a High Dynamic Range display gamma curve to HDR content with support for PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. The HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction.
Focus Assist controls the aperture level of a video signal and displays images on screen with sharpened edges to help camera focus operation.  False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: zebra, variable, ARRI, and comparison.
Built-in Camera Log to Linear Conversion LUTs
The monitor has built-in Camera Log to Linear Conversion LUTs from various camera manufacturers, including Log-C, C-Log, S-Log2, S-Log3, J-Log1, and more. Plus, custom 3D LUTs can be imported for accurate and consistent color matching between different displays and for DIT previews of customized 'looks' that have been created by third party color-grading applications. The LUT-converted content can then be output to downstream devices/monitors via the SDI loop out.
  • Postium Korea OBM-R210Q 21.5" Quad-Split Rack Mountable 3G-SDI LCD Monitor
  • Rack Mount Kit
  • Limited 2-Year Manufacturer Warranty
SKU: OBM-R210Q
$5,825.00Price
