Postium Korea PRM-503A Overview
The PRM-503A 2RU LCD Multi-Channel Rack Monitor from BON features three 5” 800 x 480 LED-backlit LCD panels with a 90° tilt range. Input selection and full PRM series feature-set menu is accessed via the front panel. Input and output ports include two SDI in with one SDI loop out, CVBS in, CVBS loop out, RJ45 remote control, and a serial firmware upgrade port.
Multi-format support (480i, 576i, 720p, 1080i, 1080p, 1080psf, 2K)
Three 5” HD 800 x 480 resolution, 16.7 MP wide screens
Small Footprint occupies only 2RU of a standard EIA 19" rack
Assignable remote control
Closed Caption: CEA-608/708
H/V delay and AFD
Wide variety of marker & safety area including user defined marker
Blue Only and Monochrome
HD/SD-SDI 2 input & active loop through
Composite input format auto detect
Composite input & loop through
SDI input format auto detect
Embedded audio level meter (16-channel) - Vertical/Horizontal
Source ID function (user defined in OSD function)
Timecode display
Selectable full & small size, Waveform (Y Cb Cr)/Vectorccope-HD/SDI (SDI only)
Postium Korea PRM-503A Triple 5" LCD 2RU Multi-Channel Rack Monitor
DC Power Adapter
